Salta al contenuto principale
Lanciato il 26 ottobre 2018. Modelli A1984, A2105, A2106, A2108. Disponibile in versioni GSM o CDMA / eSIM, nano-SIM o dual-SIM / 64, 128 o 256 GB / Bianco, Nero, Blu, Giallo, Corallo o Rosso.
468 Domande Visualizza tutte
iPhone keeps going into dfu mode after restore
Hi there, I’m having trouble with an iPhone, Its the XR, When you connect it to iTunes/3U tools the phone is recognized by both as being in DFU mode, When you click on restore/update the phone begins to restore, when its completed and reboots it goes straight back into DFU mode, I have tried to take it out of DFU mode with no joy, I’m hoping someone has come across this before. Thanks.
Questa è una buona domanda?
Punteggio 0
1 Commento
same problem any solution
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
Does the phone came in contact with liqiud ? If not try to connect your iphone to Itunes or 3U Tools with a disconnected cam and screen, only connected to your logic board is dock connector and battery and then do the update/restore. After the update/restore you can connect the screen, camera etc one by one so you know where the fault is.
Punteggio 1
1 Commento:
Thank you for your reply, I have had a look inside the phone and it does not look like it has any liquid damage, I will try what you said and let you know.
da
/am facing the same problem any solutions?
Punteggio 0
Aggiungi la tua risposta
James Cairns sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 138
