Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modello 1660, 1778. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
2264 Domande Visualizza tutte
I attempted a screen repair
Hey guys this is my first visit post on the forum.
Im looking into buying faulty tech & refurbishing for profit so I’m sure I will be back many more times.
I attempted a screen repair on my iPhone 7 which I dropped a couple of months back, it had a few cracks on it. I tried taking the screen off with a heat gun, i couldn’t take it up & got frustrated & ended up trying to pry it up through a hole next to the home button. Think I goosed the LCD up even more lol ???.
ive got an LCD digitiser screen to replace it with would it still do the trick when I attempt it again?
Many thanks
Rob
Questa è una buona domanda?
Punteggio 0
1 Commento
Ok thanks for your response bud much appreciated I’ll post back when I’ve had a go at it ???.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
The iPhone 7 is not a difficult phone to open if you do it properly. First off I hope you removed the two Pentalobe screws at the bottom of the phone. When applying heat with a heat gun make sure to keep some distance as those things can get very hot! The phone should just be a bit hotter then it’s comfortable to hold. Start by heating at the bottom edge where the home button is and use a suction cup to get a pick under the screen and cut through the adhesive.
Follow the screen replacement guide carefully to do this properly. You only seem to have damaged the screen even further, but should still be replaceable.
PS: Try to be well rested and calm, as you’ll easily damage components beyond repair if you’re frustrated.
Punteggio 2
Aggiungi la tua risposta
Robert Evans sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 36
