Salta al contenuto principale
The Sega Game Gear portable gaming device was released in 1991 in competition with the Nintendo Game Boy.
41 Domande Visualizza tutte
Game Gear only works when plugged in, not with batteries
My game gear stopped working when I turned off my car when I was playing it using the car adapter and when I tried to turn it back on with only batteries it didn’t work, tried different batteries and cleaning the terminals but nothing. I used to be able to plug it into a wall then after it was turned on I could unplug it from the wall with batteries in it and it would still work, but it stopped doing this, it still works with the rechargeable battery pack though. What should I do?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi @blazefenix ,
As it is working when using the external power supply you would have to open up the console and check if the battery terminal wiring is OK between each of the terminals of each of the batteries to the next and between the two battery compartments and then onto the “power board”.
As there are 6 x 1.5V AA batteries they would need to be connected in series connection (example only - same principle for 6 batteries or more depending on what voltage is required as they add up) to get the 9V required for the console to operate. The positive end and the negative end of the “battery” i.e. 6 x 1.5V, would need to be connected to the board.
It would take only one broken wire or connection for the console not to work as the battery supply would be open circuit
Here are some images taken from the ifixit Sega Game Gear Screen Replacement guide to show what I mean.
The image on the left shows what I think may be the power board as the DC-In jack for the external power is there as highlighted. The image on the right shows the wiring between the battery compartments.
(click on image to enlarge for better viewing).
If the wiring seems OK and continuity tests with a DMM (digital multimeter) of the wiring proves that it is OK between the battery terminals and the power board then further testing would be required on the board.
Hopefully a start.
Punteggio 0
1 Commento:
Thank you! I will definitely try this!
da
Aggiungi la tua risposta
Todd Patterson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 37
Tutti i Tempi: 1,107
