Screen on boot up scrolling. Then going white
When I boot up the screen is scrolling up reall fast and then it starts fading to white. What is causing this please I can’t use my MacBook now.
Questa è una buona domanda?
@markstill45 - You'll need to plug in an external monitor to be sure. If the external screen is showing this as well then your logic board (CPU) will need to be replaced. If not then its the internal display (T-CON)
Ok mate tx.
I’ll have to work out how to do that, and which cable to get.
Depending on what you find with your test will aim us to which part to replace the logic board or the display.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 34
Can you post a short vid so we can see what you are seeing Aggiungere immagini ad una domanda
da Dan
Done that Dan. Also tried pram reset. Took back off to check ribbon connection to screen all looks ok.
da markstill45
