Salta al contenuto principale
High performance tablet computer released by Apple on November 11, 2015. Model A1584.
131 Domande Visualizza tutte
Anyone got the schematics of the iPad?
Does anyone own the schematics of the iPad 12.9”?
I would need them to repair the touch filter
Update (21.01.2021)
OK following things are broken the touch filter is burnt and the solder lines too, I’m searching for a point to put a jumper. Does anyone have experience with that
Questa è una buona domanda?
Punteggio 1
3 Commenti
iPad Pro 12.9" Teardown
Are you talking about this, or what do you mean specifically?
da
I meant from the circuit because the Filter for touch is completely burned and the solder line and no one knows where to put a jumper wire
da
brother, touch function has no filter coils on circuit in that model. Directly to touch controllers (there are two). Interface is closed inside metal bracket (big one) on screen flex. I guess the burned lines are near the connector. Submit a photo - I'll explain.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
hello Expolosions&,
those don't exist. All we use is knowledge and experience in electronics gained through years of work.
I would use 120ohm/450mA circ.20%. If it can't stand it change on 240ohm / 350mA circ.20%. That’s all.
  • regards,
Update (01/25/2021)
hello Explosions &…
its absolutely 240/350mA 0201 coil in VDD_screen line, connected to 3 near connector pins and small capacitor right. The other side goes straight to 8566 backlight ic (see picture).
  • regards
Punteggio 1
2 Commenti:
I think you got it wrong my problem is that the solder line is completely burnt and I need to find a pout to put a jumper wire
da
da
Aggiungi la tua risposta
Explosions & Explosions sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 61
Tutti i Tempi: 1,125
