Replacement Display without faceid
I am about to buy a replacement display to determine whether or not the display is causing my device to appear dead. However, in order to be able to return the display if that´s not the issue I am trying to figure out if the display would work without attaching faceid and just plugging in the two display flex cables. Thanks.
Questa è una buona domanda?
1 Commento
Keep in mind that you disconnect battery cable first then you can disconnect screen flex etc. , after you taken of metal bracket.
da Leslie Leslie
