Salta al contenuto principale
The Huawei Honor 10 is an Android smartphone released in May 2018. It has a 5.84" LCD display, 4GB of RAM, a dual 24 and 16 MP main camera, a 24 MP selfie camera, and a front-mounted fingerprint sensor.
17 Domande Visualizza tutte
Where is the WiFi and GPS antenna located?
After replacing a water damaged screen, every component seems to work fine except for WiFi and GPS.
WiFi works only if I am 1 meter away from the WiFi router, which seems really odd. As soon as I move a bit away it disappears.
GPS seems really unreliable and inaccurate, not useful to navigate in traffic.
I would like to know where the components are located in this phone to replace them.
Thank you!
Questa è una buona domanda?
Punteggio 0
1 Commento
Im searching for this too it was solved im gettin horrible gps signal after tech repair
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi @dansanher ,
I don’t know about the GPS antenna but here’s a composite image taken from Steps10 and 12 of the ifixit Huawei Honor 10 Screen Replacement guide, showing the location of both ends of the WiFi antenna where it is plugged into the boards.
Check that the cable is securely connected at both ends
(click on image to enlarge for better viewing)
Punteggio 2
2 Commenti:
Hi Jayeff!
Thanks a lot for your answer.
I’m a self-taught family phones fixer, hahaha, I knew that was an Antenna but I thought it was the Network and not the WiFi Antenna, or perhaps it is both?
I will try and reconnect it and see if it improves.
Thanks!
da
@dansanher
GSM antennas (example only) are different ;-)
da
Aggiungi la tua risposta
Daniel sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 784
