Salta al contenuto principale
Prodotto per la prima volta da HP nel 1979.
stopped working after wrong battery installed
Battery store installed too powerful a battery (somehow same size as N type so fit} in HP 41CV and it never worked again with N Type. Person said it was “fried” and gave a different model replacement.
Is it possible to fix or is it permanently damaged from overload.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi,
It may be possible to fix it but looking at the start of the troubleshooting section in the service manual, you will need an ET-11966 service rom module and a port extender to start performing the tests to know what may be the problem.
I can’t find either online, you may have better luck
Punteggio 1
Aggiungi la tua risposta
Kevin Kuehn sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 306
