Salta al contenuto principale
The GameCube is Nintendo's fourth console gaming system. Repair is simple and requires only common tools.
20 Domande Visualizza tutte
Why is there no video?
So my GameCube has no video, but it has sound. Further inspection shows that only the red input is working and not the white and yellow.
i tried switching cables and that didn’t work.
thanks in advanced
Questa è una buona domanda?
Punteggio 0
2 Commenti
Hi,
Have you proved that the the AV input (yellow - video + red & white - left and right audio) on the device (is it a TV?) that the game cube is connected to is working OK, you didn't say? You only said that you changed cables.
Try connecting another device that has an AV output to the device, e.g. a dvd player and check that there is video and audio when using it to determine whether the problem is in the game cube or not.
da
Hi! So I tested the same cables and TV with another GameCube I have, and it works fine.
Thanks!
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hi,
Here’s a video that may be of some help with locating the problem.
Also here’s the ifixit Nintendo GameCube guides as well which may help with getting access to the component parts
Punteggio 1
How about check to see if the video connector has a bended pins or damaged pins?
Punteggio 0
1 Commento:
There at no bent or damaged pins
da
Aggiungi la tua risposta
David Lank sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 107
Tutti i Tempi: 8,749
