Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modello 1660, 1778. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
iPhone 7 Audio controller problems. Not standard problem
iPhone 7 Intel board with standard problem Audio IC.
Job that have been done:
  1. removed chip
  2. checked for connections
  3. restored jumper to R1103
  4. New chip installed
  1. The problem is that when phone is switching on - Apple logo bootloop
  2. As soon I break installed jumper to R1103 - everything booting properly, except no voice recording.
    • No Shorts been found.
** Checked with Thermal camera - nothing heating.
  • Tried 3 controllers. Same issue.
    • Power supplier showing nothing abnormal. Max 0.3 Amp
  • Any ideas? Processor issue?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione prescelta
I found problem myself. resistor is broken next to the charging connector. someone break it when tried to disassemble motherboard
Punteggio 0
Risposta più utile
Have you completely ruled out parts? If jumper is removed it boots. If jumper is connected it brings other components into play like the front flex assembly and the charge port. I have been doing audio IC’s for a long time and have not run into the exact problem you are facing without the problem being parts.
I have seen the D12 pad develop a crack or R1103 become nudged off the rear pad but none of them showed your symptoms but it might be an idea to check them.
Punteggio 1
Aggiungi la tua risposta
Aleksej Barinov sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 2
Tutti i Tempi: 107
