Salta al contenuto principale
Repair guides for the Samsung Galaxy J5 (2015), released June 2015.
20 Domande Visualizza tutte
Samsung galaxy J5 screen flickering
hello.
I have bought this Samsung Galaxy J5 2015.
it works for a minute, then the screen starts flickering with random colors and its glitching and then it turns off, but the phone is still on. (as seen in photos).
what do I do?
thanks for your help
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi,
You could try to mirror the screen to determine if it is a display problem or perhaps a systemboard problem, before you open up the phone.
If the mirrored image is OK then more than likely it is a display problem or display connection problem, although it still could be a systemboard problem but this is less likely.
The phone will need to be opened and the display flex cable connection to the systemboard checked to ensure that it is a secure. If it appears to be OK then the display will have to be temporarily replaced and the phone checked to see if it is now OK.
Here’s a teardown video that may be of some help.
Replacement displays are available online. Just search for Galaxy J5 2015 LCD Digitizer Display Replacement to get results for suppliers.
Punteggio 5
Aggiungi la tua risposta
Kapy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 543
