Salta al contenuto principale
Repair and support for ceiling-mounted bladed fans.
20 Domande Visualizza tutte
Why won't my lights turn on?
My remote controlled hampton bay ceiling fan lights wont turn on. I've changed all the bulbs and have made sure there is power to the fan as well as made sure the remote will still turn the fan on. But the light will not come on.
Questa è una buona domanda?
Punteggio 0
2 Commenti
Hi @enragedblob ,
What is the model number of the fan?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi @enragedblob
Are the wires from the light connected to the fan wiring?
The user manual (p.13 Fig.15) is not very clear but it shows the 2 light wires connecting back into the fan housing.
If they are both connected OK then check that the dip switches in the remote and the receiver box are both set the same. It maybe that if they’re not, that it may operate the fan but not the light. Not really sure if this is the case but still worth verifying.
If the wiring and switches appear to be OK, what is the model number of the receiver box in the fan?
With most remote controlled fans, the power supply wires goes into the box and then its outputs are wired to the fan motor and the light so that when a remote control signal is sent to the receiver, power is turned on/off/varied to the appropriate outputs by the receiver box.
Punteggio 1
Aggiungi la tua risposta
Stephen Fischer sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,060
