Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modello 1660, 1778. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
2265 Domande Visualizza tutte
Why does replacement home button only double tap and nothing else?
i recently had a home button that didn’t work so i bought a new one and it doesn’t work, its connected and it doesn’t even click. but it does double tap.
ALSO:
i have recently found out that the backplate of the replacement home button has fell of. id this the reason why it doesn’t work? and how can i fix it
https://www.amazon.co.uk/dp/B07ZD6NC1Y?r...
have i been scammed or lied to? or is it something else
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
First of all, don’t buy parts on Amazon
Second, it’s a YF button, it only works with taps and doesn’t really do an original click, like try just tapping it once and it should act normal
Punteggio 0
2 Commenti:
it doesn't act like "normal" after i tapped it once. what should i do ??
da
Return it and take it to a local repair tech
da
Aggiungi la tua risposta
matthew einstein sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 69
