Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
Steam damage No audio
Device was used in hot tub for over an hour and has suffered steam damage. Replaced the lightning connector and battery but no audio. Works fine with headphones. Replaced the loud speaker and still no audio.
Do you think it could be a faulty replacement lightning connector or perhaps more serious such as the audio chip or a logic board issue?
I replaced the lightning assembly originally as the device had charging cable issues which are normally rectified this way.
Thanks for any pointers.
Hugh
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
It is most likely a faulty charging dock. If your headphones work it will not be the audio IC. The only other component would be the speaker amp but I would rule out parts first.
Punteggio 2
Aggiungi la tua risposta
Hugh Livingston sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 46
