Salta al contenuto principale
Versione migliorata del Nintendo Game Boy Advance, l'Advance SP è stato rilasciato il 23 marzo 2004 in Nord America, con una struttura quadrata ed un design a conchiglia.
No Display on IPS Screen Mod?
I recently bought an IPS display kit from AliExpress for my GBA SP (The knockoff “one-chip” variation, not the Funnyplaying IPS kit). I’ve found that when I power the system on, the screen backlight turns on, but no picture is displayed. On occasion, the display will work properly and no further issues will occur until the system is powered off and back on again. Then the display goes back to no display, backlight only for another six or seven on/off cycles.
I took the system apart and cleaned both the ribbon cable and the ribbon connector on the board with isopropyl alcohol and made sure that the ribbon cable was seated correctly in the connector. I buttoned everything back up and for a little while it was a bit better, displaying a picture more often than not. But after an hour or two it went right back to the way it was before, only displaying a picture every so often.
I’m almost certain there’s nothing wrong with the board as this GBA had a standard AGS-001 display that worked perfectly well before replacing the screen. My best guess is that the ribbon is causing the issue. I’ve read that it’s possible that improper insulation could cause a short, but I added the insulation film that came with the screen to pad the metal backing of the screen, so I wouldn’t think this to be the issue. It could be the screen, but it does work just fine when the system decides to display correctly, so I’m not sure.
Has anyone run into a similar problem in the past? Any ideas would be greatly appreciated. Thanks in advance!
Questa è una buona domanda?
Punteggio 1
1 Commento
Hello,
This is same for me, I buy ips screen kit from china to upgrade a game boy pocket and just the light work good.
No display with this screen...
I think that is not the good hardware or don t work before.
da
Aggiungi un commento
1 Risposta
Risposta più utile
Hi Danny,
This sounds like a broken ribbon cable (adapter).
I bet the screen and motherboard are still good to go. This is most likely a broken ribbon adapter.
Best thing to do is to return it and ask for a new one.
Punteggio 2
4 Commenti:
Definitely going to give this a go. I’ve already reached out to the seller about a replacement, we’ll see if it works out. Thanks for the suggestion!
da
My pleasure! Hopefully you'll get back to gaming fast :)!
da
Slight update on this situation; I happened to have another ribbon adaptor and LCD that I took from a different build that I could use to isolate the problem. I tested both the original, possibly faulty LCD with the working ribbon adaptor and the original faulty ribbon adaptor with the working LCD. I found that both LCD screens worked perfectly well with the ribbon adaptor that I know works, and both LCD screens had the same issue with the potentially faulty ribbon adaptor. Seems pretty clear that it’s definitely the ribbon adaptor at fault here. Looks like I’ll need another ribbon adaptor after all!
da
Hi! Alright! That would explain you need a new ribbon adapter yes. Thanks for letting us know :)!
da
Aggiungi la tua risposta
Blockyboxguy sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 13
Ultimi 30 giorni: 62
Tutti i Tempi: 5,606
