Salta al contenuto principale
The Black and Decker AS150 Steam Advantage Iron is a white and aqua hand-held iron with pivotal cord.
Leaking water from bottom whether is on and off
Black and Decker house iron , leaking water from bottom whether is on or off when up right positions when not using ( maybe crack internally/water tank/water system)?
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi @charlieccc ,
What is the model number of the iron?
You may have to dis-assemble it to see where the leak is and whether or not it can be easily repaired. For example it may be a faulty gasket rather than a split in the tank
Punteggio 3
3 Commenti:
Thank you Jayeff!
da
Sometimes you cannot get a gasket. High temp RTV could be very helpful.
da
how to repair it.please upload video.
da
Aggiungi la tua risposta
Charlie Charlie sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 32
Tutti i Tempi: 2,550
