Need to replace existing SSD— what do I need?
Would I still need purchase the temperature sensor? What else do I need?
TIA!
Questa è una buona domanda?
TIA!
If your system came with a blade SSD and you are replacing it with another blade SSD you don’t need a temp sensor Sostituzione SSD Blade iMac Intel 27" Retina 5K Display
If you are replacing the SATA HDD or installing a replacement SATA SSD instead of the blade SSD then you will need the thermal sensor Sostituzione Hard Drive iMac Intel 27" EMC 2546 here’s a kit with everything you need iMac Intel 27" (Late 2012-2019) SSD Upgrade Kit
You might need a HD SATA cable if you are installing a new SATA SSD drive instead of the blade SSD Sostituzione cavo SATA iMac Intel 27" EMC 2546
Prodotto
$100.99
Guida
Difficoltà:
Difficile
1 - 2 hours
Guida
Difficoltà:
Difficile
2 - 3 hours
Guida
Difficoltà:
Difficile
1 hour
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 51
