Need to replace existing SSD— what do I need?
Would I still need purchase the temperature sensor? What else do I need?
TIA!
Questa è una buona domanda?
Modelli A1419 / Fine 2012 / Processori 2.9 & 3.2 GHz Core i5 o 3.4 GHz Core i7, ID iMac13,2
Rep: 11
TIA!
If your system came with a blade SSD and you are replacing it with another blade SSD you don’t need a temp sensor Sostituzione SSD Blade iMac Intel 27" Retina 5K Display
If you are replacing the SATA HDD or installing a replacement SATA SSD instead of the blade SSD then you will need the thermal sensor iMac Intel 27" EMC 2546 Hard Drive Replacement here’s a kit with everything you need iMac Intel 27" (Late 2012-2019) SSD Upgrade Bundle
You might need a HD SATA cable if you are installing a new SATA SSD drive instead of the blade SSD Sostituzione cavo SATA iMac Intel 27" EMC 2546
Prodotto
$159.99
Guida
Difficoltà:
Difficile
1 - 2 hours
Guida
Difficoltà:
Difficile
2 - 3 hours
Guida
Difficoltà:
Difficile
1 hour
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 26
