Salta al contenuto principale
Lanciato a giugno 2012. Modello A1278. Processore Intel con Turbo Boost. Fino a 512 MB di RAM Video DDR5
1624 Domande Visualizza tutte
Faded corners in the display of MacBook Pro Mid 2012 13 inch
Hi Guys,
Hope you are all doing safe!
Jumping on to the top straight away, I am having a white border fade issue in my macbook pro mid 2012 13” inch.
This fade is surely due to hardware issue (not sure if the display is the issue or something else).
The edges of the display is faded while the 4 corners have the maximum faded area as shown below:
Is it worth to get a display replaced for the model? Or Can I use it as it is?
I am happy to use it in the current way, but little skeptical if this fade would keep on increasing day by day :(.
Do you guys have experienced this issue earlier?
Please put in you suggestions and thoughts here.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Avinash™ Kumar what you have here is a failing display. Yes it could “f this fade would keep on increasing day by day” but it can always buy you some time before you have to replace it. In the meantime I would suggest use it until you feel it is time to either replacing it and/or keep it connected to an external display.
Sostituzione schermo MacBook Pro 13" Unibody metà 2012
Punteggio 2
Aggiungi la tua risposta
Avinash™ Kumar sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 419
