Flashing green lights on the GR-4N?
OK appliance repair people, puzzle me this - red center light is lit, two temp lights are flashing green. Is this the secret Christmas tree mode, or something less stealthy?
Questa è una buona domanda?
@matt89134 apparently this is a failed controller issue. Interestingly enough those are actually hard to find. If you can follow this guide Cuisinart Griddler GR- 4N Knobs Replacement and post some good pictures of the controller boards with your QUESTION. Maybe we can find something that is out of whack :-) Aggiungere immagini ad una domanda
Guida
Difficoltà:
Molto facile
2 - 5 minutes
Guida
Difficoltà:
Moderato
15 - 20 minutes
Thanks - fixed with big electronic cleaner spray bath on electronics.
I have the same issue. I am going to try thay spray cleaner now. For me, it seems like it has a problem with the loosing electrical contact. When I put something on, it looses contact, but when I open the lid, it works
any specific product you could suggest and what exactly you did to fix it? please provide more details, thanks
I have the same issue. Did you figure out the spray to use and where?
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 27
Tutti i Tempi: 1,428
1 Commento
Fixed it. Previous to the failure it got a degreasing, and I think some of the oily water got on the electronics . I just hosed the guts with electronic cleaner, and flushed with 99% alcohol. Fixed the problem
da Matt Schneider
