Salta al contenuto principale
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
How do I connect a on/off switch to my MacBook
Hello hi,
How do I connect an on/off switch to my 2009 MacBook A1181?
I did try connecting the a red wire to the first power on pad then a black wire on the 2nd power pad but I clicked it on the on position and it doesn’t turn on I would like to know what I'm doing wrong thanks!
Questa è una buona domanda?
Punteggio 0
2 Commenti
Can you fill us in a bit more here. Is the system working properly now via the keyboard or is that the issue?
da
Yes the 2009 a1181 macbook motherboard works good I just wanna add an off and on switch instead of buying a keyboard thanks but idk how to wire it up
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
It sounds like you have a very messed up keyboard so you really have no choice here other than replace the upper case (keyboard). Here’s the guide you’ll need to follow Sostituzione Case Superiore nel MacBook Core 2 Duo and here’s the needed part MacBook Top Case, Keyboard, US (SR/08/09) White (recycled), Apple P/N 922-9550
Punteggio 1
Aggiungi la tua risposta
Kenneth shawn sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 93
