Salta al contenuto principale
Repair and service information for the Lenovo IdeaPad 305. Released in 2015, the Lenovo IdeaPad 305 line consists of 3 bright colors and Dolby Advanced Audio.
Why does my Laptop stuck in running circle?
So It all started today after I finished my online classes and well My laptop just stuck and wont start. I tried turning it on and off and pressed all the button and stuff but still it won't work and this is the only thing that shows up
. Help I really want to fix this as soon as possible because of my online class. Thank you
Questa è una buona domanda?
Punteggio 0
1 Commento
Maybe hard drive died.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi,
Try the following:
Turn on the laptop and when it boots into Windows, force turn it off by holding the Power button until it completely shuts down.
Do this 3 times in a row i.e start > boot > turn off > start > boot > turn off >start > boot etc.
On the 3rd attempt it should boot into the Windows Recovery Environment menus.
When in the menus select Troubleshooting > Startup Settings > Advanced > Startup repair and follow the prompts.
If that doesn’t work try Troubleshooting > Startup Settings > Advanced > System Restore or System Image Recovery (if you have a restore point set or system image that is).
Do not select Reset this PC. If you choose a wrong option after this you may lose all your data as Windows will be reinstalled.
Punteggio 1
Aggiungi la tua risposta
Silver Acetate sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 15
Tutti i Tempi: 426
