Icemaker wont produce ice
If there is no flow of water to the ice maker what is the failing component that caused this?
Questa è una buona domanda?
If the water inlet valve is defective, or if it has insufficient pressure, it won't allow water to flow through. As a result, the ice maker won't make ice. The valve requires at least 20 psi to function properly. Make sure that the water pressure to the valve is at least 20 psi.
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 73
1 Commento
@yarddawg what is the exact model number for your fridge?
da oldturkey03
