Salta al contenuto principale
Repair information and support for GE Profile Refrigerators.
79 Domande Visualizza tutte
Icemaker wont produce ice
If there is no flow of water to the ice maker what is the failing component that caused this?
Questa è una buona domanda?
Punteggio 0
Commenti:
@yarddawg what is the exact model number for your fridge?
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
If the water inlet valve is defective, or if it has insufficient pressure, it won't allow water to flow through. As a result, the ice maker won't make ice. The valve requires at least 20 psi to function properly. Make sure that the water pressure to the valve is at least 20 psi.
Punteggio 1
Aggiungi la tua risposta
Jeffrey Paul Young sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 59
