Salta al contenuto principale
Samsung's robotic vacuum featuring Wi-Fi connectivity. Model number: VR2AM7070WS/AA.
9 Domande Visualizza tutte
Vacuum Motor upgrade help
Hi. I have a very important question. Samsung powerbot vr7040 has 10w motor, can I replace this motor with 20w motor used in other models like vr7065 vr7070? Is there a problem with the electronic circuit? What kind of work should I do? I would be very happy if you could answer. Thanks.
Questa è una buona domanda?
Punteggio 0
1 Commento:
Hulusi Şen wondering why you would want to do that
da
Aggiungi un commento
1 Risposta
The motor wouldn’t work, because the 20W motor would try and draw 20W from a 10W connection and circuitry, which would shut down the PowerBot or fry the circuits. I’d heavily recommend looking for the proper part.
Not sure where’d you’d find the part, but good luck!
Samsung POWERbot R7070 Vacuum Motor Replacement
Punteggio 0
1 Commento:
I understood. I got the answer I was looking for. thank you very much.
da
Aggiungi la tua risposta
Hulusi Şen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 6
Tutti i Tempi: 92
