Salta al contenuto principale
Samsung POWERbot R7070 Vacuum Motor Replacement
Cosa ti serve
  1. Samsung POWERbot R7070 Vacuum Motor Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the emergency switch off.
  2. Samsung POWERbot R7070 Vacuum Motor Replacement: passo 2, immagine 1 di 2 Samsung POWERbot R7070 Vacuum Motor Replacement: passo 2, immagine 2 di 2
    • Remove the two exposed screws on the top right of the device.
  3. Samsung POWERbot R7070 Vacuum Motor Replacement: passo 3, immagine 1 di 1
    • Lift the cover plate to expose the battery.
  4. Samsung POWERbot R7070 Vacuum Motor Replacement: passo 4, immagine 1 di 2 Samsung POWERbot R7070 Vacuum Motor Replacement: passo 4, immagine 2 di 2
    • Using one hand, pinch the white plastic connector where the battery's wiring connects the POWERbot. Pull up to disconnect.
  5. Samsung POWERbot R7070 Vacuum Motor Replacement: passo 5, immagine 1 di 2 Samsung POWERbot R7070 Vacuum Motor Replacement: passo 5, immagine 2 di 2
    • Lift the battery from the right side, up and out of its compartment.
  6. Samsung POWERbot R7070 Vacuum Motor Replacement, Motor: passo 6, immagine 1 di 2 Samsung POWERbot R7070 Vacuum Motor Replacement, Motor: passo 6, immagine 2 di 2
    • Unscrew the two silver 1.5 cm screws on the left and right side of the battery compartment.
    • Remove the two 1.5 cm screws above the yellow sliding lock tabs.
    • Remove the two 1.2 cm screws in the brush compartment.
  7. Samsung POWERbot R7070 Vacuum Motor Replacement: passo 7, immagine 1 di 2 Samsung POWERbot R7070 Vacuum Motor Replacement: passo 7, immagine 2 di 2
    • With moderate force, separate the silver top from the black bottom of the vacuum.
    • The cover will only separate a few inches as the two halves are connected by wires.
  8. Samsung POWERbot R7070 Vacuum Motor Replacement: passo 8, immagine 1 di 1
    • Disconnect the white and red wired connector attached to the top half of the base of the vacuum by squeezing the connector and pulling up.
  9. Samsung POWERbot R7070 Vacuum Motor Replacement: passo 9, immagine 1 di 1
    • Pinching the top and bottom of the black wired connector, pull outward, fully detaching the top from the bottom of the device.
  10. Samsung POWERbot R7070 Vacuum Motor Replacement: passo 10, immagine 1 di 1
    • Detach the wide circuit connector on the left side by pinching and pressing down on the right and left side of the clip, pulling the connector out.
    • Pull the connector out by the left and right side of the white clip and not by the wires.
  11. Samsung POWERbot R7070 Vacuum Motor Replacement: passo 11, immagine 1 di 2 Samsung POWERbot R7070 Vacuum Motor Replacement: passo 11, immagine 2 di 2
    • Remove the four 1.2 cm screws.
    • Remove the single 0.8 cm screw.
  12. Samsung POWERbot R7070 Vacuum Motor Replacement: passo 12, immagine 1 di 1
    • Remove the two 1.5 cm screws on the motor chamber.
  13. Samsung POWERbot R7070 Vacuum Motor Replacement: passo 13, immagine 1 di 2 Samsung POWERbot R7070 Vacuum Motor Replacement: passo 13, immagine 2 di 2
    • Lift the motor by grabbing the body of the motor, lifting upward.
    • With the screws removed from the motor chamber the top of the motor chamber will pop open.
Conclusione
Altre 8 persone hanno completato questa guida.
CSU Fullerton, Team S2-G8, Bruce Fall 2017 Membro di CSU Fullerton, Team S2-G8, Bruce Fall 2017
CSUF-BRUCE-F17S2G8
3 Membri
10 Guide realizzate
6 Commenti
Anybody know where I can get the motor?
donstatus87 - Replica
I'm getting a Power brush error. Does the motor contain the power brush square socket and gearing?
Steve.
Steven Nicholas - Replica
One can actually open up the motor housing and take out the metal motor. Be careful not to break the clips when opening the housing… because I did…. but duct tape will prolly hold it together again. Anyway , the motor bears the following markings in my R7040: VCM-140CLDA DC21.6V 145W 2018.5.22-12.50
Have fun!
websites140 - Replica
Easy to replace and found a refurbished motor on eBay.
David Trinkle - Replica
Thanks for this guide! My motor was making a high pitched whine and grind - bought a replacement refurb motor on eBay for $39; hope it works.
joey - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 31
Tutti i Tempi: 4,085
