Salta al contenuto principale
The Samsung Galaxy A10e is a lower-mid range Android device released by Samsung in February 2019. Identifiable by model numbers SM-A102(U, U1, W, or DL).
24 Domande Visualizza tutte
Are the guides for the Galaxy A10 applicable to the Galaxy A10e?
I can't find a guide on this site specifically for the Galaxy A10e. Is it ok to follow the guides, specifically the screen replacement guide, for the very similar Galaxy A10?
Questa è una buona domanda?
Punteggio 1
1 Commento
This may be a silly question but just curious. Can you fix the Samsung Galaxy A10e after you get it wet? I have a spare but wanted to double check before using it.
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
Youtube can be a great thing as well: https://www.youtube.com/watch?v=x7Ui_KZf...
Good luck!
Punteggio 4
1 Commento:
Thank you so much!
da
Hi Kenneth,
I just had the opportunity to repair the charging port on an A10e, so published a guide for that. In terms of internal layout, the A10e is nearly identical to the A10; the only important difference is that the motherboard cover is in two pieces on this phone that both need to be removed, as opposed to the single piece on the A10.
Hope this helps!
Punteggio 4
Aggiungi la tua risposta
Kenneth sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 6
Tutti i Tempi: 478
