cracking sound from the speaker
cracking sound is coming in medium and high volume of speaker and when the speaker gives up bass
Questa è una buona domanda?
@kuleshwar could be a bad speaker coil or ripped speaker cone. You will have to take it apart and check the speaker separately. Of course there is always the chance that this is a bad amplifier (IC or circuit) again you won’t know until you check. Take a look on here for a teardown. After that post some good pictures of your pieces with your QUESTION so we can see what you see and possibly help you further.
this happened to my sister it was just water damage
Same issue with my srs-xb10.
I’ve opened it just to found its actually the speaker itself having tear within its diaphragm. Sigh
Hi i had the same problem that you, my speaker was cracked on my SRS-XB10. I tried fixing it with some Aleene’s Original Tacky Glue but it didn't work because there were many cracks and the speaker was just good for the trash.
I found one seller on Aliexpress that sells a 52mm speaker that looks almost exactly like the original Sony SRS-XB10 speaker and weights the same so probably the same Power. I ordered it, replaced the broken speaker with the new one (perfect fit) and it works like a charm, I didn't notice any major sound difference.
If you are interested the Aliexpress seller is "SOTAMIA Overseas Store" and search for "52mm 10W 4 Ohm Speaker"
do you think this one work work
https://www.aliexpress.us/item/325680398...
kinda wanna go over board lol
Ultime 24 ore: 2
Ultimi 7 giorni: 20
Ultimi 30 giorni: 77
Tutti i Tempi: 4,933
2 Commenti
Down speaker damage change a parts
=== Update (11/15/2020) ===
Hello bass speaker change
da Shamim Khan
Where am i supposed to get the new bass diaphragm for replacement?
da akhash11
