Popping/Cracking Noise when zooming
When the camera is powered on, the lens makes a small cracking noise while extending. Other than that it works normally. How can I fix this?
Thank You!
Questa è una buona domanda?
Thank You!
Andrew Jensen sounds like you may have some dirt/debris in there. Other than disassembling the lens and trying to clean it, which is a challenge without proper manual, there really is not anything you can do to fix it. Only other thing is to replace the lens Panasonic Lumix DMC-ZS60 Camera Lens Replacement
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 637
