Salta al contenuto principale
The digital camera was released by Panasonic in July of 2016. The Panasonic Lumix DMC-ZS60 has 18-megapixels and wifi mobile device connectivity.
Popping/Cracking Noise when zooming
When the camera is powered on, the lens makes a small cracking noise while extending. Other than that it works normally. How can I fix this?
Thank You!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Andrew Jensen  sounds like you may have some dirt/debris in there. Other than disassembling the lens and trying to clean it, which is a challenge without proper manual, there really is not anything you can do to fix it. Only other thing is to replace the lens Panasonic Lumix DMC-ZS60 Camera Lens Replacement
Punteggio 0
Aggiungi la tua risposta
Andrew Jensen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 18
Tutti i Tempi: 951
