Salta al contenuto principale
Lanciato il 21 settembre 2018. Modelli A1984, A2105, A2106, A2108. Disponibile in versioni GSM o CDMA / eSIM, nano-SIM o dual-SIM / 64, 256 o 512 GB / Silver, Gold o Space Gray.
375 Domande Visualizza tutte
Can I do a front glass only replacement at home?
I don’t want to spend a lot of money on a new display when my one works perfectly fine, the only issue I see is needing a OCA LCD Glass Vacuum Laminator Machine but theyre expensive, is tehre any way to do it without them
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Risposta Più Utile
You have a premium phone that cost a thousand plus dollars when it was new and there’s a reason for that and apple certainly didn’t use cheap parts to make it. Because that phone uses an OLED panel, glass only repair on them is near impossible without thousands of dollars in special tools you’d be better off replacing the whole screen assembly like every other cellphone repair shop would do, such as myself. It’s unfortunate that you broke your device but by trying to cheap out on the repair isn’t going to make it any better. However, you can do the repair yourself and if you really don’t want to pay a whole lot to fix it, you could order an LCD replacement screen rather than an OLED. But there are a few caveats to using an LCD. It has increased energy draw compared to OLED, which can impact battery life and you do run the risk of damaging the display connector because it’s not designed to handle such a high current draw. You can order them from mobile sentrix for around $85 plus shipping and tax but it doesn’t include tools.
Punteggio 2
If you need to ask, you can’t do it.
If you want to do this kind of DIY repairs to save money, you’ll usually end up spending even more than buying a brand new phone.
Unfortunately above rules are very common in Apple DIY repairs.
Punteggio 1
Or find a shop that will do the job for you, I think if you let them do only glass refurbish on your original screen it won’t cost you a arm and a leg. Glass only repair is possible for around €75,-.
Punteggio 0
Aggiungi la tua risposta
mosminecraft4 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 13
Tutti i Tempi: 330
