Salta al contenuto principale
Features an Intel Core i5 CPU, Intel UHD Graphics 620, and a 14 inch Full HD 1920 x 1080 pixel display.
Can I fix my screen myself?
I broke my screen on the top right corner. I also broke it where it bends. When I turned it on it works but I get the different arrange of colors, 3 extra screens on top of each other, and I can see the crack from the inside that shows me my laptop screen is broke. But, I need to know can I manually fix it myself? Also if you anyone has any step by step instructions I would that. Thank you.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi @weirdmyst ,
Here’s the hardware maintenance manual for the laptop.
Go to p.51 to view the necessary pre-requisite steps and then the procedure to remove/replace the LCD unit.
On p.76 part #3 you will find the part numbers for the LCD panels (make sure that you only look at the Ideapad 330S-14IKB column).
Search online using the appropriate to your particular LCD panel type part number only, in the search term of your browser, to find suppliers of the part that suit you. Usually the part number can be found on the back of the LCD panel if you wish to verify that you are ordering the correct part.
Punteggio 2
1 Commento:
Aggiungi la tua risposta
Michelle Sterling sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 13
Tutti i Tempi: 419
