Salta al contenuto principale
The LG Stylo 4 is a stylus-equipped midrange slate-format Android smartphone released by LG in 2018. Identifiable by model numbers L713DL and Q710(AL, CS, MS, TS, ULM, ULS, and US).
20 Domande Visualizza tutte
Wont charge past 2% tred differet cords
My phone will not charge past 2% is there any guids that can help me fix it? I had it for 2 years dont want to pay $80 to take it to the shop
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
@chefnoyes start off with a new battery. After that you will need to check the charging port. If that is okay you will need to check the components on the circuit board. One suspect would be a bad power management IC but there are plenty more suspects. I would replace the charging port flex since that would eliminate most other suspects. You can get a replacement at places like this Once you replaced the battery and find you have to disassemble your phone post plenty of pictures with your QUESTION so we can see what you see. This video will at least get you into the phone.
Aggiungere immagini ad una domanda
Punteggio 0
Aggiungi la tua risposta
joe sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 239
