Salta al contenuto principale
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 Domande Visualizza tutte
PS3 hard freezes right after launching an app/a game
As in the description
I own a fat PS3 VER-001. It had a period of around 3 years when it was unused.
Now as I powered it up, did all the updates and stuff, chugged in a good ‘ol Sacred 2 disc and fired it. The end. Smooth transition to black screen. TV re-reported 1080p (as if the video resolution was reset) and my PS3 is frozen solid. No reaction to controller, black, 1080p screen (reported resolution stays until PS3 is turned off).
No sound at all
No reaction to controller by any means(couldn’t turn the console off/controller off)
When turned off, with a pwr button, it beeps once, starts blinking the power led and then beeps twice (as if it realized it was frozen) and turns off
No error upon the nesxt power-up is shown
No “fix” related to safe mode helped (filesystem or database rebuilding/formatting)
Happens in all the games I have on physical discs, PS Home and PS Store (with PS Store, Playstation logo is shown and we’re back in the freeze afterwards)
I have found no topic related to that particular issue, please, correct me if I’m wrong
EDIT:
Additional information and findings:
The freeze happens on opening PS Home, PS Store, any PS3 game disc
During the freeze, the PS3 draws constant 90W from the wall
It’s a CECHL04 model and all the voltages are spot-on (within 1%) with the specsheet
Updates pass without an issue
Rebuilding a database or other safe mode hacks did not work, an entirely new hard drive did not work either
The controller does not pair when frozen
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
5 Risposte
Hello, I believe you have an overheat issue, as you mentioned you didn’t use your PlayStation 3 for years, so your console is surely full of dust, so you need to clean it and verify if the fans are spinning correctly.
You can follow the ifixt guide to walk you through the steps.
Punteggio 0
8 Commenti:
Hello @vertinhol !
Firstly, thank you very much for your input into my issue.
You've given me a great reminder to mention that I've been digging into the physicality of a console.
I have had it apart as much as you possibly can, and cleaned it as much as I could from the inside out. From a mechanical standpoint, the console is flawlessand as clean as a new. The fan spins and the thermal interface between the dice and the cooler has been refreshed.
I have even thought of hot-air treating some components in despair, but I am by far not knowledgable enough to be sure I won't break anything.
da
Maybe you didn't reassemble it correctly and you forgot to re-plug something which is probably not true but worth the shot, also I'm wondering if it's a PSU issue, because when you run a game the PlayStation will draw more power during that process, and if your PSU can't provide it then it will shut down.
da
@vertinhol great idea for a baseline of diagnostics!
So I measured voltages on the 4-pin connector and on the main rail prongs throughout an entire cycle from power-on to an attempt of launching a game and it maintained constant 12.04V on a main rail, didn’t even drop by 0.01V when froze.
The 4-pin rails were dead still as well at 4.80V, 3.13V, GND, 5.48V
Having taken a look inside, I must admit that I found my re-assembling job pretty good, nothing is loose on the inside (thermal paste reapplied, of course)
da
@gosteczek the voltages must be 5V, 3.3V, GND and 5V, I don't know if the difference you found can lead to instability or not, but assuming it doesn't then maybe somehow it's a software issue, can you restore the PS3 to its factory settings, also check if there are any updates before doing that.
da
@vertinhol whoah, I must admit that nearing 5.5V on what should be a 5V rail sounds scary, I will try to tackle voltages levels next somehow.
As for software, I tried re-building filesystem and fixing potential database problems with safe-mode settings. I went as far as to putting in a new, clean hard drive and performing latest version OS flash from USB drive, which completed successfully. Unfortunately, however, the problem persists is exactly the same way I found it on a fresh system. I guess it's just a next variable eliminated.
Still, I'm very thankful for your input into my issue
da
Mostra altri 3 commenti
I’m having the same issue, tried everything.
Punteggio 0
2 Commenti:
It's quite interesting that I saw little to none traces of the problem online, I'm really surprised not to see other ps3 users reporting the issue, but I hope that we will find a solution to this problem.
Lack of backwards compatibility for PS3 absolutely sucks, I undestand the decision from a business standpoint, but nevertheless, if you can't get your hands on the aftermarket ps3 or your game does not work on like rpcs3, you're screwed :/
I hope someday and answer to this will be posted and we will get our PS3s fixed!
da
Hello, I've recently had the same issue. I have a few digital games on my ps3 slim and they run great, for hrs. When I put a disc in it will run for 10mins maybe. Then the sound will quit and the screen will turn white but at the bottom it will still say EA sports. Ive taken it apart and cleaned it thoroughly, I've cleaned the blue ray sensor. Everything seems fine. I have no clue what is wrong. I've even done the reformatting. Like I said, digital versions run great for hours. If anyone has any suggestions or fixes please comment. Thank you.
da
Have you got it solved because I’m having the same issues I’ll say I haven’t done as much as you but my ps3 is doing the same thing
Punteggio 0
1 Commento:
Anyone found a solutions to this?
da
Solutions? Anyone? I have the same issue
Punteggio 0
Hello. I am new to the PS3 game but just letting everybody know, I have this issue. I PAID 50$ for this console and was told it did not work at all. Got home and she booted right up. It was filthy… Filthy. So i spent a couple days cleaning every last piece of it very carefully. I reassembled it, put some high quality thermal grease, and the disk reader does not work to my surprise. Haha, I updated to custom firmware then quickly realized that was a very stupid decision for this PS3. I reverted to OFW 4.90 and I have tried swapping and formatting the hard drives, I have tried re-updating it again and again. I have yet to see if it will read a PS2 Game or PS1 game but the disk reader eats the disk and starts spinning no problem, don’t let me forget to mention that the console gets very very warm to the touch because the PSU gets up there in the temp. All the heat comes from the PSU. The board it chilled. It makes me sad. I have 4 ps3 fats. One is refurbished from gamestop I paid 40$ for and it works. The other needs a disk reader, and this one needs something. I am here because I need help. My other ps3 fatboy has ylod… been cleaned and new thermal grease. Still ylod.
Punteggio 0
Aggiungi la tua risposta
Ork Martin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 39
Ultimi 30 Giorni: 137
Tutti i Tempi: 9,301
