Salta al contenuto principale
Repair information for Sharp televisions.
105 Domande Visualizza tutte
Will it work by replcing a single metal dome?
Hi there,
I have recently encountered an issue with my Sharp smart TV remote controller, I managed to disassemble it and one of the mental domes was damaged, it won't bounce back up.
So I wonder if I replace just the damaged mental dome, will it working again as normal?
The thing I need to do is that peeling off the adhesive tape with metal dome on it.
Please help me, thank you very much!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
@v3nuo take a picture from the other side and post it as well. Those “domes” look like microswitches. You would need to replace it completely to repair the remote
Punteggio 2
1 Commento:
Hi @oldturkey03, thank you very much for your quick reply, I have tried to peel off both the damaged metal dome and a working one, as they are completely independented, so I can easily peel them off.
I will try to replce the damaged dome with a good one, and see how's it going, thanks again for your kind reply and help.
da
Aggiungi la tua risposta
Albert sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 66
