Display distortion at certain lid angle, horizontal lines
Display distortion at certain lid angle.
Is it possible that there is loose contact somewhere (where?)?
How to access display connector?
Questa è una buona domanda?
Ouch! Not good!
Sadly, there is nothing you can do to fix this other than replacing the display assembly MacBook Pro 13" Retina (Late 2016-2017) Display Assembly and here’s the guide Sostituzione schermo MacBook Pro 13" Touch Bar 2017
Apple altered the design in the Touch Bar & Fn systems of the display splitting the T-CON logic from within the lid to the uppercase in doing so they extended the LCD lines via a set of ribbon cables connecting to the T-CON board in the case. Sadly these ribbon cables are soldered to the two parts and not serviceable which is why you need a new display assembly
Here’s a more detailed view:
The Purple ribbon cables are the ones affected here. Either you have a damaged cable or you got wetness into the T-CON logic within the metal can.
Most of the time we see Blue cables fail FlexGate when’re the backlight cable goes and the iSight camera which is a mirror on the other side.
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 118
