Salta al contenuto principale
Modelli A1419 / Fine 2012 / Processori 2.9 & 3.2 GHz Core i5 o 3.4 GHz Core i7, ID iMac13,2
330 Domande Visualizza tutte
No power plz help
I replace the blade SSD, RAM, and 3.5 with a 2.5 SSD.
I did a full tear down following the guide by iFixit. I rebuilt the machine I followed the guide in reverse.
When I first applied power I got three system beeps. I looked up the beep codes, the RAM that I installed was not seated correctly. When I fix the ram issue, I applied power back to the machine. And nothing!
No beeps no fan spinning and no LED diagnostic lights on. I further researched and found that if no diagnostic lights are on then possibly the PSU has gone bad.
My question is would it be the PSU or the main logic board?
Any and all help is appreciate it.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Boy, you went to the boards here!
Altering so much at once makes diagnostic process hard.
So we need to reverse some of the alterations to see if we can isolate out the cause. Lets start with the easiest, put back the original RAM did that change anything? Next disconnect the 2.5” SSD (just leaving the blade SSD installed) Did that chance anything?
What blade SSD did you install? Did you put in a custom Samsung or OWC SSD or something else?
Punteggio 1
2 Commenti:
Hi Dan,
So I did what you said and replace the blade SSD back into the modo. And nothing changed. I tested the PSU, it is outputting voltage, but that is as far as I got. I do believe that it went straight to the mobo. Im not giving up tho, it will be a cold day before that happens. It's 105 outside now!
I installed a 500GB something else w/adapter(m.2 m key 2 blade).
Please let me know what your thoughts are about my next move.
Thanks
da
So after messing with the machine this morning, everything original, but with no Ram I did get it to power on and led lights lit up. But after installing RAM the machine went back to being unresponsive. Just keeping whoever is watching in the loop.
da
Aggiungi la tua risposta
Shawn sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 29
