Salta al contenuto principale
The original Xbox is Microsoft's first widely popular video gaming system. It has an easily identifiable black case with 'XBOX' emblazoned on the top and front. Repair is easy with common tools.
How to put top case back on?
It red ring of deathed, turned out to be the disc drive was goofing up and i fixed it by plugging the ide cable back in again. How do i put the top on? I got the front metal clips to clip but cant get the ones on the back of it to clip into place
Questa è una buona domanda?
Punteggio 0
2 Commenti
Did you read through the repair guides?
Xbox Original
da
@aactech yeah. I dont know if i bent the tabs, i also dont know which way to bend them back
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi!
Actually, the top case goes right on. First the back side and then the left-right side - front side (worked for me).
Punteggio 1
2 Commenti:
Yep! Got it. I must have bent those aluminum pin things, but bent them back. Its not perfect, but its way better than almost not even on
da
Great :)! Yes, sometimes you need to bent them a little and then it will snap on!
da
Aggiungi la tua risposta
Dylan Devries sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 961
