Salta al contenuto principale
The Dyson V6 Absolute is a cordless, bagless cleaner released in September 2014, with HEPA filtration that captures allergens. Used for all floor types and weighs 5 pounds. Identified by model number SV09.
19 Domande Visualizza tutte
vacuum cleaner works on-off
Situation: 2 years old V6; canister is empty and clean ; the motor filter is clean. the MAX button is OFF. All is OK with the cleaner. BUT:
After a full charge, motor kicks out after 2 minutes of operation- put on charge again for one minute- motor starts again for an other minute- put on charge few more minutes- vacuum cleaner OK for ONE minute; and so forth. Could the life of battery has ended?
Note: on the body, the light is solid blue when in operation and flashing every time the cleaner stops.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
If your Dyson v6 Absolute vacuum cleaner unexpectedly turns off during use, see the Dyson v6 Absolute Shuts Off While In Use problem page for possible causes and solutions.
Punteggio 0
The absolute shut off problem pages doesn't address this problem. All the fixes have been gone through and it still shuts off all the time.
Punteggio 0
Aggiungi la tua risposta
Jean Claude Bourcier sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,283
