Salta al contenuto principale
Device and repair information for the 60" LED HD TV by Samsung released in 2013, model number UN60FH6003FXZA.
Why is there a black vertical line on screen?
The actual device is a 60” 2013 LED Smart TV (F6350 Series) UN40F6350AFXZA
A thin verticle black line has recently appeared on my tv screen.
I ran 3 screen test and it failed all of them.
How do I fix this?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@livenlearn … this is a failed tab driver for your panel. it is either a loose connection or on its way out. you could try and take the bezel off and gain access to the tab it corresponds with in that section. gently apply pressure to the tab and see if the line dissipates. if so, you can wedge some soft foam and re assemble the set. at some point, its going to fail completely. if its under warranty, act now. if not, prepare yourself for a new set down the line.
Punteggio 2
Aggiungi la tua risposta
Ang sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 264
