Which bolts go where
The power steering pump the belt pulleys the tensioners the water pump the thermostat all have been removed I know where they all go I just can't figure out which screws go where for 98 Nissan quest
Questa è una buona domanda?
Hi @ladykayak1966 ,
Here’s the 1998 Nissan Quest Service Repair Manual
Click on Contents: Steering.
When you have the file on the screen (select Fullscreen to make it easier to see and use) go to p.ST-22 onwards to view how to disassemble/reassemble the power steering pump.
The others sections of the manual, e.g. engine lubrication & cooling systems and engine mechanical will help you with the others.
There is a download icon at the right side end of the document header bar if you want to download it to your computer
Hopefully this is of some help.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 102
