Salta al contenuto principale
Rilasciato a luglio 2018, il MacBook Pro da 15", modello A1989, adotta uno schermo retroilluminato a LED da 15,4" con tecnologia True tone, Touch ID e processore fino a esa-core Intel Core i9.
203 Domande Visualizza tutte
Display issues on MacBook Pro 2018 15"
I have thick green lines appearing vertically on the screen on the login window. After I login I see random flickering blue lines on the screen. I have updated the MacOS to the latest version, reset PRAM and NVRAM but the issue still exists. What might me the reason?
Questa è una buona domanda?
Punteggio 0
8 Commenti:
hey! i am facing same issue u gotwhats the solution to this?
da
@Muaz - If you still have AppleCare+ I would go to Apple to get the display replaced as it will be cheaper. Otherwise you'll need a new display assembly Sostituzione Schermo MacBook Pro 15" Touch Bar 2018
da
I dont have under apple care+ man.maybe i was wondering if it was MacOs problem because it used it with care no physical damage was done etc or maybe it will fix it by it self.dont know only harsh can tell me the conclusion because it just happened to him month before.
Some times it all prefect even start up screen was perfect during macOS update.
If this gives u any clue
If avoid blue area that pops up in start up for normal usage there is no problem at all no flickering etc.but it starts flickering when around that area is used for rendering any clue!
I want to avoid replacement bad af because just bought this laptop few weeks ago! I rather buy 4k/ 2k 144Hz monitor then getting new display
da
This issue has been happening to hundreds of people, I paid huge for a top of the range MacBook Pro and it barely lasted the two years and the screen did the same thing. It’s a manufacturing fault that Apple won’t admit. The opening and closing of the screen destroys the thin cables that attach the LCD to the main body, it is moulded together so in the past you could replace the cables but now they force you to pay for an entire new display which costs 50% of the entire price of a new machine. It’s got nothing to do with software or updates don’t be a fool. Apple refuse to acknowledge their manufacture fault and are raping the consumers blindly. I will NEVER purchase another Apple Mac again. Wasted my money and time.
da
Mine fell to pieces about 2 weeks before the 2 year warranty was up, but we were in strict lockdown and I couldn’t get my computer to a dealer. When I eventually got my computer there they weren’t interested in helping me. Mine was the latest Touch Bar. I spent a fortune and they gave me a faulty machine and did nothing about it. Goodbye Apple
da
Mostra altri 3 commenti
Aggiungi un commento
1 Risposta
This is a tough one! The bar is telling me the T-CON board has failed, and the sporadic horizontal line could also be a logic board issue with the VRAM.
Best to get this system to an Apple Store or authorized service center as it could be costly. Get an estimate first before you let them fix it.
Punteggio 0
2 Commenti:
T-CON issue is same as the flexgate issue? Also any idea how much will repair cost me? The machine is out of warranty.
da
No, different! FlexGate was a ribbon cable which happens to connect to the board in question which powers the backlight. In this case there is also logic on this board deals with the raster of the signals to the horizontal and vertical lines that make up the LCD panel. This is the logic that has a problem here. Review Step 18 in this teardown Smontaggio MacBook Pro 13" Function Keys versione fine 2016 Apple uses the same logic across the 2016 13" & 15" through to the current 2020 16" systems.
da
Aggiungi la tua risposta
Harsh Khajuria sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 21
Tutti i Tempi: 2,199
