220mA to 570mA Battery drain
Hi,
I have a tricky fault on my 2008 Honda CR-V.
Basically, there is a drain on the battery which continuously goes between 220mA and 570mA every10 seconds or so.
If I remove fuse 16 under the bonnet (10A) the problem goes away. This fuse is described as “back up" And I don't know what it does besides keyless entry.
I'd now like to remove fuses down steam of fuse 16, but I can't find any wiring to use as a reference.
Can anybody give me a way forward?
Thanks,
Luke
Update (08/02/2020)
Loom is pictured drivers
inside leg
Questa è una buona domanda?
1 Commento
Unfortunatly removing the fuse shuts down too many functions at once.
You will need to unplug each individual component and retest for the draw.
da Brett Carlo
