Is there away to install Bluetooth to the tv
Is there anyway to install Bluetooth to the tv so I can look for speakers and use the better remote
Questa è una buona domanda?
Hi,
Here’s a link that may help you to connect a Bluetooth speaker to your TV, if it hasn’t already got the Bluetooth feature.
https://drive.google.com/file/d/1RR8Q8hw...
Here is the manual.
Your tv does have bluetooth support so if you browse through it, you should be able to connect devices :)
Hi @chris_p ,
Did you notice the caveat in the manual about Bluetooth? (see p.18)
"This function is not available on certain models in specific geographical areas".
You are correct @jayeff, guess i've missed it.
Hi @chris_p
You may still be right as the manual is not really model/location specific. It is used for all the TV models in the Samsung Series 6 range, which can be misleading
At least if you are correct, then the manual will show them how to connect a Bluetooth speaker.
Cheers.
If the TV doesn't offer Bluetooth, a Bluetooth to WiFi bridge (smart) might be possible. You need one thats able to be programed like a RaspberryPi unit.
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 8
Tutti i Tempi: 309
