iPhone 6S battery drain - 0.02A draw before prompt to boot
So, I have a working iPhone 6S, boots normally, charges normally, everything works but it discharges the battery faster than normal. Even when the phone is not powered on something is draining the battery and after like a day battery is dead.
First, I thought it’s a tristar issue and I replaced it with a new one, but the problem is not solved. Then I thought that maybe the battery is bad so I replaced it with a new one, but problem is still present.
When I connect the board on DCPS I get 0.02A draw before prompt to boot. I have checked PP_1V8_ALWAYS and I get 1.8V, I also checked PP_BAT_VCC and I get battery voltage, so I guess these lines are OK?
I have also probed around tristar and tigris and I didn’t find anything wrong, no shorted caps. I also did diode mode measurements on all connectors and all readings are OK.
What can I try more, what could be a problem?
Questa è una buona domanda?
I also tried with alcohol and freeze spray to find a short but no luck, nothing gets hot.
I also noticed that all caps on PP_GPU line "beeps" but I'm guessing that this is my multimeter issue because TP1100 and TP1120 are 10 and 23ohms. I also checked the other 6S board and it also beeps on PP_GPU line.
da betrocker
