Salta al contenuto principale
La Enclave può ospitare sette passeggeri, con la possibilità di aggiungere un divanetto nella seconda fila al posto delle due poltrone standard, aumentando la capacità a otto posti. È dotata di serie di trazione anteriore, con l'opzione della trazione integrale.
Rpm jumping while I'm driving
I jus had spark plugs an condenser replaced had the car a month now . As I'm driving I am noticing g the rpm are jumping unless I press more on gas or idle out the gas myself. Before I call this pos service department my son who always used this site .I figured I ask first. My son jus passed away this month so now I have no one I can trust to ask an it kills me all over again..
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
I’m sorry for your loss. How many miles are on it? If the RPMs are jumping it could be related to the transmission. It could be slipping or having a hard time shifting. Can you post a video of the RPMs jumping? And are there any check engine or transmission lights on the dash?
Punteggio 0
I'm having the same issue! No check engine or transmission lights on…have 70,000….hope someone can help! Ps, truly so for your loss; my sincerest condolences.
Punteggio 0
1 Commento:
Common problem with these is torque converter shudder often mistaken for a misfire
da
Aggiungi la tua risposta
brown.candiann sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 18
Ultimi 30 giorni: 42
Tutti i Tempi: 4,208
