Screen lines vertical and horizontal
help please
I tried to replace the flex cable my self the cable that connects the mother board to the screen. Unfortunately after i turned it out to try it before putting all the screws and everything back. The screen is not working at all not even with the old cable. Mac is turning on I can heard. I can even play music guessing what I am doing. And also by using with the Touch Bar. I connected to an external monitor with the c cable but is not working. Please help I am freaking out I fell I make it worst by trying to fix it myself thanks.
Questa è una buona domanda?
2 Commenti
Can you post a picture or vid so we can see what you are facing Aggiungere immagini ad una domanda
You talk about using an external monitor, does it work properly?
What cable did you try replacing? I'm a bit confused, there are four different cables!
da Dan
after trying to replace the screen now it has the following issues.
The screen is not turning on at all before it got lines.
the external monitor is not working for some reason nothing on the screen. it used to work fine.
da gabriel galarza
