Salta al contenuto principale
Il Lenovo IdeaPad 310 Touch-15ISK è stato rilasciato nel luglio del 2016. Il Lenovo IdeaPad 310 Touch è specializzato per le attività multimediali.
Right side DC IN port needs to be replaced.
July 9 2020
Hi there, i tripped over the cord as a result the “in” part of thr port slanted and tore. that caused it to not grip prperly so i often had to press and wiggly in order for the pc to charge and the battery indicator light to go on. well, one fine morning when I plugged in again, the cgarger part , which has some yellow platic, crumbled. I purchased another charger it does not have the yellow plastic in the inside . PC light does not turn on or charge.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Hi @greeneli
Here’s the hardware maintenance manual for the laptop.
This details the necessary pre requisite steps and the procedures to access the components in the laptop.
Here’s a link to just one supplier of the part. It is only to show what it looks like and the cost of the part. There are other suppliers online that may suit you better. Just search for Lenovo IdeaPad 310 Touch-15ISK Dc-In jack to get results
Punteggio 1
Aggiungi la tua risposta
Eli sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 15
Ultimi 30 giorni: 27
Tutti i Tempi: 230
