Salta al contenuto principale
Il Samsung Chromebook Pro può essere identificato dal numero di modello XE510C24.
The touchscreen doesn't work
The touchscreen is completely unresponsive. The Chromebook works perfectly otherwise, but doesn’t respond to a finger or the stylus on the touchscreen. I also don’t get the notification when I take out the stylus. I’ve tried factory resetting, but it doesn’t change anything.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta più utile
you could try and disassemble the unit and clean the contacts and reseat the connections to see if this works. secondly, i would try and install all updates and drivers associated with the model. thirdly, i would check the settings in bios or os settings to ensure that the functionality is indeed enabled and working properly. with all three of these steps done, you will find an error somewhere or will be in the ballpark of what to troubleshoot. start here for diasassembly and reseating the cables/ cleaning contacts, then proceed with updates and so on:
Sostituzione dello schermo del Samsung Chromebook Pro
post back with any findings for further assistance.
Punteggio 1
2 Commenti:
Bingo! Seems like the digitizer was disconnected. I've had a lot of battery problems with this chromebook and it must've come undone during one of the replacements.
da
good deal...great job on the repair.
da
Aggiungi la tua risposta
Ellis Herman sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 24
Tutti i Tempi: 790
