Salta al contenuto principale
Lanciato il 20 settembre, l'iPhone standard di Apple del 2019 ha LCD touchscreen da 6,1" e doppie fotocamere ed è disponibile in sei colori. È il successore dell'iPhone XR.
475 Domande Visualizza tutte
iPhone 11 Face ID
My Face ID in iPhone 11 damaged when my phone screen broken , where can I found Face ID part , please
iPhone 11
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Risposta Più Utile
Transfer ambient light sensor and flood illuminator from original flex to new flex
Punteggio 2
Your front camera and earpiece speaker/proximity sensor assembly cable is paired to the motherboard you can't change the parts because you will lose face Id because the parts will not be paired. The only way to keep face Id is take it to a Apple store or A certified Apple repair store and let them fix it. It doesn't matter where you get the parts it will not work because Apple controls that.
Punteggio 1
For Face ID issues, I would either get apple to fix it, or see if you can salvage the camera by your self. Like @barriphone stated "Your front camera and earpiece speaker/proximity sensor assembly cable is paired to the motherboard you can't change the parts because you will lose face Id." If you break the camera while trying to replace the screen, you will lose Face ID. Could you upload a picture of the top of the screen by where the camera assembly is located?
Punteggio 0
Aggiungi la tua risposta
Yasir Ahmed99 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 591
